R100gs Rear Brake Upgrade -
I along with many early GS owners have encountered rear brake problems.
I have undertaken many upgrades to my bike (as many others also have) and I felt it would be remiss of me to make improvements to my bike without addressing the issue of the rear brake.
I am aware of solutions previously adopted by others for example:
1. Changing the back end for a r1100gs set up (no doubt there are other reasons for this upgrade but the ability to fix a disc to the rear has to be one of the reasons for this change).
2. HPN rear disc upgrade - I seem to recall that HPN offered a mounting plate for a rear disc (aswell as HPN's upgrade to an inverted brake cam enabling continued use of the rear shoe system)
3. Welding tabs on to the brake cam so that the shoes would move further apart.
So what is the problem and are all R80/ 100 gs's affected?
Assuming the brake drum is within acceptable tolerances (mine was and I drew this conclusion because I could adjust the rear brake so that they stuck on), the main issue seems to be that the brake pedal does not have sufficient movement to actuate the brake cam without the brakes been adjusted so that they are continually rubbing. What system do I have? - I have the one with the oddly shaped brake cam and shoes.
I used to have a r65 and it had brake shoes and I found the back brakes worked very well - at least as well as the rear disc brake on my 1983 r100rt (probably the best bike ever made in my view).
The r65 had a flat edged brake cam and the shoes had a flat end. It semed to me that a better spread of the shoes would be available for a more limited pedal movement if I used this earlier form of brake cam with the appropriate shoes. Indeed I think this system was used on 1991 onwards GS models.
I bought a new flat brake cam on ebay and appropriate shoes and am pleased to report a significant improvement on stopping power. So if you want a cheap solution to rear brake problems you might like to try this out.
Any works you do is obviously at your own risk and I accept no responsibility (sorry!)
Photos attached showing new cam, new shoes and old type of shoe
