Tall screen fittings on 02 1150gs
maxwan
Yorkshire
Hi everyone, looking for some help on fitting one of these screens .
https://rover.ebay.com/rover/0....uk/ulk/itm/143326457332
I've taken my old one off and put the new one in situ . The problem is I think I am missing some spacers .
On the new screen there seems to be an inch and a half space to connect the bottom securing two screws .
The photos are attached for your help in what's missing or if the screen is for a later model gs1150 .
Hope this makes sense .
Thanks Paul
Sent from my Nexus 6P using Tapatalk
That looks like it is for a GSA, the Adventures have wider screens. The spacers are available, you could try Motorworks.
edit: Just found the via the item number, yes it is for a GSA.
I think you need the fittings for a GSA screen.
Thanks lads , is there a name or part number I can use to search .
www.motorworks.co.uk/vlive/Shop/Parts.php?T=6&Q=FAA28697
Hi , will this be what I'm looking for, and is there anything else I need besides left and right .
Not 100% sure as I have a GS not a GSA. However, if you look here there are also support plates and 3 different screws listed.
Hope this helps.
https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=59030&rnd=07242017
edit:
The same thing from another source:
https://www.realoem.com/bmw/enUS/sh...MW-R_1150_GS_Adv_01_0441,0492_&diagId=46_0772
buellzebub , thank you. I'll look into it ,
The screen is for a GSA so to fit to a GS you need the two larger screen spacers , cover plates and fixings screws , parts 3,4,5,6 & 7 shown below :
The spacers go between the screen and the front panel carrier - shown here with red circles
Thanks John . I'm looking into it . Cheers
Spacer
Hi Paul
You do need the ADVENTURE spacer parts 3+5
Morning albatross .
Yes please if you have them or know where to source them from. Thanks
Morning albatross .
Well Paul,
They are rather expensive to buy, the only ones I could find are the these ones...
If you need linguistics help drop me a pm
This chaps full mobile No tel:0049-170/2829484
Thanks albatross very much for your time help. I'll talk to motor works and price it all up and if your findings work out cheaper I'll pm you . Great help .
Hi John , thanks for that , have them a call and there checking stock and getting back to me. If it's to expensive I shall go down albatross route ,
IMHO, unless you're over six feet tall, the standard ZTechNik in smoke is what you will want. Anything higher and there will be buffeting. I've got over 120k km on mine and think it is the best upgrade yet for my 2002 R1150GS. Just saying. All the best and enjoy the ride. The difference is unbelievable. Cheers, R
Hi Rhodes , giving it a go . I'm only 5.8 tall . Tried three helmets . Not be out till the better weather though . ( fair weather rider ).
I've got a pair of tobinators that I now realise are for the standard screen, not the adventure. Is there a kit to adapt one to the other??
