No offence taken Sir, and I would agree thatl Husky have made a good looking bike
The advantage of not having a fuel tank up front is the bike is a lot slimmer between yer legs (ooh err misses) which I quite like, but it obviously shifts weight more to the rear. I've fitted a 5 litre Rade tank to mine where the big air box used to be, which has given it well over 200 mile range, but that's not anywhere near what you'd get with the LR Husky version.
To be honest, the 701LR is still very slim as the tank up front is mainly forward and down.This gives you an idea :
So, back to my bike build.....decided to give up waiting for mate’s help.He promised to help me and I even offered to pay him, as he’s shit hot on the tools,unlike me.
But he said of course he didn’t want paying and would love to help,and would set aside a day this week to do it.He hasn’t, and when I messaged him the other day just to borrow a step drill bit, he said he was too busy to even go look in his garage for a few days,even though he’s furloughed...
So anyway, sod it.....in for a penny.....
I read and re-read the Nomad instructions and then dived in.
Starting with this :
Took the seat off,disconnected the battery and then took the front tank panels off, then unbolted the filler cap and undid the front tank so it could slide back.
Then I labelled all the wiring within the headlight and undid as many connectors as possible.
Next was to cut through the plastic shroud that houses the headlight and dash etc,to aid it’s removal.
Unbolted the indicators and took the dash to pieces to leave me with this :
Next would be the hardest job of all-fitting two brackets with spacers which go either side of the ignition barrel and provide fixings for the top tower clamp.
I knew it would be a bastard as access is very limited, requiring mucho patience and a swivelly head torx bit.
This shows the issue,from the instructions,hence the orange frame but same for my 701 :
The torx bolt,circled has to be tightened from the direction of the arrow but the frame and airbox is in the way.VERY fiddly but took my time.
This then allowed the top clamp to be fitted.
The bottom clamp was another bastard as it used a U bolt which needs to go through a very tight spot behind the head stock :
But once done, you should end up with this :
Which I did:
I then constructed the tower,though not yet loctited,fitted the 12v sockets and USB socket :
Quick install to see it fits ok :
Then refitted the tank,tank covers and filler cap.
Also fitted bar risers, shown in situ above.
So that’s where I’m at. Took best part of 6 hours but no mistakes....yet.
Will sort some of the wiring/lights tomorrow and then book it in to a local auto elec specialist so they can get it all set up correctly,as going to need the LEDs spliced in to the existing wiring,and want a proper junction box thingy installed to take some of the feeds away from the battery terminals and get all the accessories correctly installed.
Then I’ll need to get the sticker kit installed properly.
The tool box/belly pan is in the post....so don’t expect that soon, given Nomad’s rather crap comms...
Still,I’ve made a good start.
