Wait a cotton-pickin minute:They look suspiciously like KTM bling to me in a 1200 /1250 LC forum post.Here you go. They’re your favourite colour.
https://www.ebay.co.uk/itm/Orange-B...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Everyday is a learning day on here.
I take it you just plug them into the key hole backwards ?
Yep
Any excuse, you know me!
Every time you wash your might steed sprat it carefully with gt85 and operate the key mechanism a few times.
Far better than a disc lock and alway with you!
Exactly this! Had one on my LC, transferred it to the XR and left it on when I sold that bike (to a mate). Original lock been on for 4 years and is still going strong with no problems at all (regularly sprayed GT85 into lock mechanism).
So good I just ordered a new one off Chris and have fitted to the KTM.
A great bit of kit
So some ACF50 sprayed into it now and again should do the trick too.
No idea, I've only ever sprayed GT85 into it, but anything that lubes and inhibits corrosion should work I guess!
Report back if you do.
Me and one of my mates have had to get ours replaced as the locks sieze.
Losing confidence fast......
Same here. It's forever seizing and one day I worry it'll do it with the pin in!!
I’ve just bought a used roadlok from sadjim and then got the spacer kit
I can confirm I used the E spacers and 90mm bolts, the D spacers will clear the caliper but lines up with a hole in disc better with the E spacers
Also the bolts have same clearance with the E’s
For those that have locks that seize or are seizing, just a heads up Ian is very fast at sending you a replacement lock, I will put his email here, he is a spot on guy, just replace the AT with @
imccarthy AT roadlok.com
Yeah done that Shaun, I've actually still got a spare lock barrel. But that's not the point though.
If it jams with the pin inside, you're stuffed.
Don't try cutting your brake disc off either, as it costs £ 200 per side to replace !!
But why bother ?
Had one on my 1290 and used it once. Waste of money and a faff to use.
I totaly agree.
If I had the mlsfortune of owning a 1290 I wouldn't bother either
If one was fitted that would double the value of a 1290 surely
One thing for sure, it was not Nutty who fitted it.
