I grabbed one from Chris the other day and my problem is limitation of equipment and the fact I'm shit at anything mechanical.
Question:
My bolts are 85mm - the only ones supplied.
Follow the included instructions and measured the 'gap' between original bolt unscrewed and top of bolt, which corresponds with spacer E, but only using a measure, so accept accuracy as not 100%.
Spacer D is obviously shorter (a tiny amount), but a shorter spacer would allow the bolt thread to go a tad further into the receiving thread.
My question is, rather than be 'short', would using the smaller spacer and going into the thread further lead to any issues?
The common sense in me says screw in more rather than less if in doubt.
I've read an older thread just this morning, which was helpful, but still undecided on which spacer.
https://www.ukgser.com/forums/showthread.php/456668-Roadlok-spacers
