What, like proving I didn't remove the handlebars, or the headlight.
The question is obsurd to start with. You ask that question to a judge and let him decide how stupid it is, when shown how a BMW rear wheel is removed.
Don't count on it. I ended up in court against Chiswick Honda - bunch of clowns). Their inaction caused the cam belt to fail with the obvious consequences. So I took them to task in an attempt to recover my costs.
The judge didn't even know what a cam belt was, let alone the potential life threatening situation that could have arisen.
So expecting a judge to understand the nuances of rear wheel removal is hopeful.
Thread resurrection I know, but I can't recall hearing the outcome of this wheel recall for late models following the alert being posted with the EU: -
I use them on rebuilds once I see fresh "Tippex" (because you can wash it off with thinners at the next fitting ) I know its torqued and done and whoever is using the bike can see at a glance if anything has moved
Once you torque something you take your tippex pen or wee bottle with a brush and you make a line from the centre of the bolt across the flange or washer and onto the surface making it in such a way you can see it as you walk up or around the bike without stooping or crawling ?
If the line on the bolt head does not match the line on the surface then the bolt has loosened
