What about gold...
Its hugely more expensive
What about gold...
German Behr spoked wheels on 1100/1150/early aircooled 1200's seem to be much stronger
Discuss
Indeed but regardless of the year the need for a grub screw tells you that inherent in the design is a tendency towards loose spokes otherwise they wouldn't be needed.
The new factor is why the spokes are not now staying tight despite the grub screw. We’re it a build process issue during manufacture you would think that would have been sorted long ago.
WC wheels aren't made by Behr
Long ago as in since the 90s there wasn't a problem...It appeared a couple of years ago....and you don't think it's due to material changes and where the wheels are built....
Hmmmm, a dubious conclusion me thinks but each to their own.
Neither were the hexheads were they? I don't recall this issue coming up with them either.
No...hence the question mark...Are you sure
I’m led to believe by my dealer, BM changed wheel suppliers around 2015/2016 and it is those wheels what have the issue, I think they have returned to their original suppliers but don’t know when that occurred.
Have a look at your wheel rims on a WC, the manufacturer's name should be etched on the rim edges
Follow the link, you will see a nice BMW GSA on the home page
http://en.giant-alloy.com/
Hmmmm, a dubious conclusion me thinks.
It might be commercially preferable to keep supplying dodgy wheels and sort under warranty as that's cheaper for BMW than cancellation.
Bmw have history on this, I believe the Mini electric power steering failures without warning. Until a well known actor used got involved after his daughter had an accidentUntil someone gets killed or maimed. If that’s BMW’s business model, then it shows a total lack of morals and ethics.
Sent from my Moto G6
Yes, you are correct. They seem to get away with anything..I think it is an industry trait. Aprilia has collapsing suspension parts in the early 2000’s involving at least 1 death and a lawsuit in NZ which was settled out of court along with a gagging order. The part was never updated or a recall issued.
Look at Vauxhall with the self igniting zafira. The government almost had to force that recall.
That's still a possibility....but I would say most likely in limited numbers. The scale of the problem suggests something more. Also folks are having wheels replaced on new bikes due to spoke tension.My understanding was the failures were due to brake calipers becoming loose and hitting the spokes.
