WC clutch swap is a piece of p#ss as it only needs front engine cover removal , it is the alternator which is a pain as it is on the back of the motor
No different to doing a clutch on a hex or TC
What?.. so you are saying the clutch on a Hex and TC are on the front of the engine?.. look again..
I think what is meant here is WC alternator replacement = Hex/TC clutch replacement in terms of effort, both being at the back of the engine.
Would pay to get the frame powder coated/galvanised while it’s apart.
You WILL get corrosion
You Plum, the Rear!
Hexhead & TC - Clutch at rear, Alternator at front - Subframe & gearbox off to change clutch
New wethead Clutch at front, Alternator at rear Subframe & gearbox off to change Alternator
The ‘new’ engine comes complete with gearbox and clutch, being low mileage it should be ok.
Is it worth messing with the alternator as it is a 2017 engine done 16000 miles?
Does anyone know if there is a static way of checking the alternator on the engine before it goes in?
No reason to think there will be any issues.
Multimeter testing etc?
Thanks Neil.It is a Solo. Has a hand winch to lift it. You can also get them with an electric winch but the hand winch is light work so no need for electric.
Nice and light and compact to store when not in use.
I have rigged up an overhead winch for engine manoeuvring.
