Removing the ABS gives you a big hole where you can mount relays and you get the added bonus of no ABS issues
Think I'll leave that well enough alone.
Would these be OK to mount the relays to?
Best way to 'tap in' is to use piggyback connectors (available from Halfords) on the appropriate wires at the back of the lamp holder.
Have you a soldering iron ? If so, cut back the insulation, tin the exposed wires then solder a trigger wire in place and wrap the joint with self amalgamating tape.
Am i the only one who doesn,t understand any of this thread? I was thinking about fitting some aux lights but changed my mind now.
I love your Fatty Balls.....
