Rod
OK OK
But....you can't get at the inside of it.......any tips, how do you guys do it ?
OK OK
Get a soft cloth - and a rubber glove... soak the cloth in lube and gently rotate the rear wheel whilst embracing the chain on the lower run...
Do not do this with engine running.....
HTH
HTH
Ooh, you’ve got me all moist!
A mate used to do similar to this on his 750/4 F2, but stoooopidly used to have the engine running and the bike in 1st gear.Get a soft cloth - and a rubber glove... soak the cloth in lube and gently rotate the rear wheel whilst embracing the chain on the lower run...
HTH
Got one of his pinkies too close to the rear sprocket one day, sprocket grabbed it and when it came out the top side it was minus the end
I bought this the other month.
Christ on a stick, it's just a fecking chain, how complicated can it be? Boys and their toys eh!
Sorry.
As you were
Andres
https://www.greaseninja.com/Chain-Lube-Accessory.html
Its a bit fiddly to get the applicator to sit correctly (because you have to bend the straw and its prone to pinging off the can), but once you've got it right, it worked very well
