From a Google search:
This is the thing, The USA uses the title "Major Highway" as a grouping, and then has sub tree categories that come off it. Nothing points to 'Major Highway' as being its own entity. I would assume that Interstates and numbered highways are what is classed as major highways, the remainder are carriageways, A & B roads.
Definition : Major Highway
A major roadway that carrieshigh volumes of traffic; the breakdown of which in descending order is:
Interstates - Federal/state financing
US numbered highways - Federal/state financing
State roads - No federal, state funding only
Local roads and streets. - Local financing only
Hardly a great guide, but...
Odd things can happen in BaseCamp. If I manually create a BaseCamp route in the French Alps, taking D roads (sort of like our smaller A roads and larger to medium and sometimes smaller B roads *) and then ask it to exclude 'Interstates' it will sometimes jump me from one D road onto another.
My best tips are:
(a) Create your own routes, don't have some dumb American'ised machine do it for you
(b) If you want to avoid motorways, simply select windy roads (or whatever it's called) but don't moan when it takes you around roundabouts, they are twisty and you can improve your "Prepare to slow but, look to go" skills, so often lacking
(c) Create some routes for yourself and select or de-select the routing options..... see what happens and try to work out what the names mean and (much more importantly) what selecting them or not, does and does not do. Play about, you can't break it
* You see how difficult an exact correlation is. You just have to sort of 'know' what the roads are like or use imagination. What do you think an Interstate would be like, if your best and just about correct answer would get you out from in front of a firing squad, when the officer had ordered "Ready! Aim!......." I bet you could think of something.....
