I have a KTM 790 Adventure and wanted to fit fog lights. So I bought a set of Denali D2 lights and CJ Designs fork leg brackets making it the same setup as on my 690.
My measurements were fine and the lights fitted ok but I just didn't like it. So I went for the KTM Powerparts setup that was now available.
What to do with the Denali D2s - fit them on R100GS PD I thought.
What to do about the standard alternator to overcome any charging shortcomings?
Found Silent Hektik 410W Permanent Magnet alternators. Fitting one of these overcomes the problem of Ignition Lamp failure causing loss of alternator output. The regulator from Silent Hektik also accommodates any
battery I care to fit; including Lifepo.
I then found that they also do a pretty advanced Ignition System that works off trigger points on the alternator rotor.
So hand deep in pocket ............
This is the result.
The quality of Silent Hektik is just amazing. Very happy.
This is the result.
