See, wasn’t that hard !
You might even be right to a certain extent .
Fuck me, praise indeed coming from you
Presence on the road ? WTF is that all about ?
A Hummer has presence but I wouldn’t want to drive one.
Should've known you two twats would start.
Entertaining as it is, STFU
Cabin fever . Probably !
Though to be fair,I’d rather buy a new Vstrom than a Shitcam,save myself £5k and a whole load of bother....
BMW GS1250 Shiftcam.....reassuringly expensive!
To get back to the original post for a moment:
He has an interesting take on this, and I do like his presentation style and wit, though I'm not sure all the criticism of the ShiftCam system is justified.
Of course, it is true that with ShiftCam the cam timing and lift settings are not continuously variable, and are therefore only absolutely optimal at two points, one for each cam, but then Shiftcam can change both valve lift and timing, where most other systems can only alter one, which somewhat offsets the advantage of continuously variable systems if they can only adjust one parameter.
Also, the reviewer has ignored the total flexibility in when the shift is activated as it is ECU controlled and not a fixed mechanical system. The fact that engine load is also a determinant for shifting the cams means the changeover point is not fixed by revs alone but also by engine load, as in how much power the rider is demanding, which I guess is measured by how far and how quickly the throttle is being opened.
The end result of this flexibility in cam shifting is that the range of possible rev/load combinations can be split across two different cams, with the engine running the most suitable cam at any point. This also means that with each of the two cams having a much smaller range of engine speeds/loads to handle, each cam is not going be so far from optimum at any point in its more limited range than a system with a single cam with its single compromise setting. I believe this also goes some way to offset the fact that ShiftCam is not a continuously variable system.
Fred
Fred
Thanks for the info , and well explained and you point out the fact the guy is a bit of a dick..
Having owned several LC GS’es the throttle response and engine feel at lower speeds (<40mph) was terrible. And that was the case on both the 14 plate original model and 18 plate update model. I would imagine the shiftcam was partly designed to improve low speed manners whilst still allowing plenty of power and punch at higher speeds.[/QUOTE
My first GS, a '14, had awful fuelling which was fixed by our sponsor. My current bike a '17 didn't need it and is happy at 1800rpm in top fully loaded.
Of the large capacity twin cylinder engines out there the 1200 r series is probably the smoothest out there, the 1250 is even better.
The shiftcam addresses a few issues. Some of them being;
Euro 5.
Pressure from the opposition, ie power.
Something to keep the annual renewers happy.
Infilling while they bring the next big change to market.
Fred
That's the best click bait there is
I'm a bit thick and don't understand?
