Well, it was all going so well.
You see, I'd had some of the exhaust studs fall off due to rusting off on my 1100GS.
I started spraying the remainder with plus gas for a couple of months, used a whole tin of it on them.
Last weekend I managed to get two of them to undo and bring the whole stud out. Great I thought. The remaining two sheared off. So four studs left sheared off.
Next step was to weld some M8 nuts on. This managed to extract two more studs. Then the fifth stud drilled out but I went skew so I re-centred the hole and put a helicoil in it.
The final one drilled perfectly down the stud. First with a small pilot and then onto the next size up. Then the drill caught and went in further than it should. A kind of oh shit further in as it suddenly went with no resistance.
Now, I've read Steptoe say that one of the studs have an oil way behind it and if you're drilling studs out not to go too deep..... I've gone too deep and into the oil way. The constant drip coming out whilst running proved this.
So, to anyone that has done this can I retrieve the situation? I've got plenty of time on my hands. I'm trying a high temperature thread sealant at the moment. I've got to wait 72 hours for it to cure. Anything else I can try? Or is it new head time?
Tom
PS. Sparkplug it's all your fault....
Finally found out how to remove the annoying signature everytime I post.....
Tom
