dpalmer_2991
Evening all!
I've looked on google and a few forums and I'm struggling to find an answer to my problem, so I thought I'd join here and see if anyone can help me directly!
Basically I was putting my GS away today, went to engage the steering lock and the key would turn all the way to the lock position, so I jiggled the bars and the key to see if it would turn fully. It didn't, however the steering lock did engage, at which point I couldn't disengage it because the key still wouldn't turn to the lock/unlick position.
After some swearing and head scratching I looked under the barrel and could see the lock pin, so I just reached in and pushed it back, and the bars move freely again. However, now if I move the bars into any position and turn the key even slightly left towards the lock position it'll try to engage the lock.
So my current worry is that the lock may come out while riding which would be less than ideal.
The Key still will not turn fully to the lock/unlock position.
Is it a case of just replacing the lock, is that possible? Or will a strip down and clean perhaps solve the issue?
Any help will be appreciated!!
Cheers, Dan
Cheers, Dan
