geezer2005
What do you use to clean your boots?
Not sure if normal polish is ok as it may damage the goretex?
Always use Kiwi boot polish and a pair of ex MoD brushes my father bought me when I left home in 1963 to join the police cadets
Brushes still going strong to this day and showing no signs of wear!
I use Daytona’s generic leather polish. Not cheap but a little bit goes a long way. I put it on, leave it to soak in overnight and polish it off the next day. I also apply it to my leather gloves *, just using any residue from the ‘on brush’ I use to apply the polish to my boots. I then polish them up with the ‘off brush’. I clean the boots at the end of each full day of use. It only takes a couple of minutes. My boots and gloves have been well used and used well, lasting for years.
If I happen to see that someone has a discount on the Daytona leather polish, I’ll sometimes just buy a couple of tubes.
* If anyone ever finds that, over winter, their summer leather gloves have hardened a bit. A quick go with a little Neutragena hand cream will sort them out.
In both of the above, the important word is ‘little’. You do not need to slather it on.
Same here, after your recommendation.
As said, a little goes a long way. A bit like me.
Not much point having the moisture from you foot pass through a goretex membrane only to find it can’t get out through the pores in the leather!I am afraid you are wrong. Gortex is the material liner on the inside of the boot, as with a Gortex liner in a jacket. Whatever you put on the outside will not affect the Gortex. However, the Gortex on the inside of a boot will have a finite life and once reached will then be ineffective.
