Was planning an all oils service, so ran my 1996 R100GSPD on private lane to warm up. One cylinder dropping all power intermittently, coming back in surges and poping and farting. running fine at idle and blipping the throttle. changed oils and plugs, cleaned around coil and sprayed WD40 all around. still the same. Ran fine before I parked up in a shed before the winter, and started it a few times to check the battery.
Could it be carb diaphragm? how do they behave when leaking?
