And breathe
Ok
start at the front of the bike
Check the plug going into the ring antenna is plugged in fully,
Check the pins in the plug are all the same height, (one hasn't backed out)
Now whether you like this or not, its the only way to do it!
From the plug in the Ring Antenna (RA)
strip the outer cable sheath off so you have exposed all the wires check them for breaks or exposed wires
Work back down the sheath of cables until you get to a cable tie.
Cut the cable tie to release the sheath of cable, and strip back to about 4 inches beyond the cable tie
Check the wiring - Keep going until you find the break or reach the ECU its the only way
Look at the picture below
This was one of two broken RA wires buried in its own sheath inside another bundle of wires !
It was broken fully in one place and near to breaking in another in 2 places!
it was nowhere near the RA, this was near/ behind the LH front suspension leg - IE no where near the RA!
The problem stems from the loom being cabled tied to tightly to the frame, as the bars turn, it puts stress on the loom at or around the
points it's cable tied.
Eventually it will fail, and EWS is displayed on the Kombi (instrument cluster)
Unfortunately until you strip & check all the wiring in the RA loom , your never going to know
Any fault codes stored in the ECU for RA are historic, it only stores the code, clearing it will make no difference
If you stuck it on a a GS 911, it will give one of two messages
RA xxxxxx fault or RA xxxxxx fault - not present now neither will stop the bike from starting
Hate to say again,
its a fiddly shitty job, but the only way to do it properly
