A question for the assembled wisdom.
I'm going to re-powder coat the cast wheels on my R80/7. As I'd rather not remove the taper bearing outer races (and then have to reset the preload) I'm planning to leave them in and mask off in the usual way. However, if I do that then I don't think I can remove the centre spacer with its two plastic rings. Any idea if they would survive the powder coating process?
Graham
With the obligatory photo!
Graham
