Has anyone built there own with their existing bike and a kit?
Any tips and recommendations?
Oh no, not another signature....
Something more far ranging. I'd like to do the equivalent of green Laning on my full suspension MTB.Are you looking for a commuter or something more far ranging?
That's the conclusion I'd come.to.as well. Is the Bafang stuff reliable? What is support like / instructions if needed?Yes, I fitted a Bafang 500W mid drive to my Specialized Rockhopper MTB. No point faffing about with changing to a rear wheel drive unit. Get a 48v system and go for the biggest battery you can afford. Some go for a 1kW drive but I see that as pointless, also be aware that the legal limit is a 250W motor. 25 mile ride is easily achieved with a 14Ah battery.
Thanks Tarka, moved.There's a dedicated forum for this kind of shite.
https://www.ukgser.com/forums/forumdisplay.php/646-Pedal-Power-including-E-Bikes
………. Is the Bafang stuff reliable? What is support like / instructions if needed?
Brilliant, thank you.Loads of Bafang spares available and YouTube videos for fitting and it's relatively easy to DIY maintenance.
I'd also recommend dumping the supplied Bafang motor Chainring and fit a Lekkie Bling Ring Chainring instead.
After over 2000 miles with my unit, the internal magnet for pedal assist (PAS magnet Sensor) broke, the replacement cost me £25. Was easy to fit following a YouTube video, which meant removing the motor from the bike to dismantle it. Here's the video I watched to replace the PAS magnet sensor:
https://www.youtube.com/watch?v=9hEUzSa7Er0&t=217s
Be also aware that with an electric motor, stuff on the bike is going to wear out a lot quicker than you would expect, so after 2000 miles I needed a new chain and rear wheel gear cassette.
I was thinking this would make a good bike to convert - Any challenges with the frame type you use
Im loving that stem
It caught my eye too....Designed for the cyclist who has bought the wrong sized bike....
What I cannot get my head around is going from three chainrings at the front to one. Surely that then means you'll be either over or under geared?
That's the bit I don't understand. The rear cassette remains the same as before doesn't it? So therefore it needs the front three cogs to give the range?The rear cassette has a much larger range - That said the high gear can spin out
