Hello all,
Firstly, I have taken a look through the many posts about the ABS system using the search feature and i cant find any answers the same as mine, also ive asked in the FB group and Google cant match my fault so here goes......
Thank you in advance in reading this, Ive joined the forum today after a few recommendations from the FB GS group.
For my history, im a very competent car mechanic with comprehensive mechanical/electrical and diagnostic skills so I will (hopefully) understand your suggestions etc for this post
My bike is a 2004 R1200GS, 25000 miles with servo ABS. I brought it last year, rode it 350 miles home and parked it up, thats where it stayed until this Virus put us on lockdown so I decided I will dedicate the time to it and get it in operation again for the good weather. The battery (15 months old) was completely flat obviously so i put it on a recondition cycle on my c-tek charger and within a day it was ready to go.
The bike cranked over perfectly for a few seconds and sprang into life.
The ABS lights where flashing as usual until its ridden to 6mph (or whatever it is) but this time they didnt turn off so after riding it for 1 minute i returned back home to double check the obvious things. Everything looked ok, brake light works on front and rear levers but i noticed that if the bike was turned off and IGN on, i could pull the front brake lever and the servo does NOT operate but the brake light does. If I push the rear brake pedal the servo and brake light DO operate but when i release the pedal, the light goes out but the servo doesnt. The servo will run continulously until the IGN is turned off.
Once the rear brake has been pressed to activate the servo, the servo sounds perfectly normal when running and if the front or rear brakes are used, the sound of the servo changes in pitch as it always does. I disconnected the battery for a couple of hours and made sure it was fully charged once more (which it was) then connected it all back up but it was still the same.
I decided to take the bike for a little ride and see if it had any characteristics - I rode it for about 5 miles with the lights flashing and everything felt fine for the first half, I found some gravel and slammed the brakes on 1 at a time and the ABS does work for both wheels.
On the way back i noticed as i pushed either brake, the servo assistance was 'coming and going' which made for very interesting stopping distances! It sounded as if i was releasing the brake then reapplying it but i was applying a constant pressure.
Now, I have a Snap-On diagnostic tool for the cars that I work on but nothing for bikes so i called my local motorbike shop who said they do have the diagnostic tool to read the ABS on this bike and i could bring it to them to read the codes for me. (as i always tell everyone - "plug in>diagnose>repair") Their diagnostic scanner said there was no codes stored. This completely baffles me as if theres a light flashing and the system is obviously not working properly, there should be a code to tell you whats wrong with it
They suggested to me to bleed the brake system through as the have seen this kind of issue with Ducati's and a bleed sorts it out so I brought it home, took the tank off and bled the system (including the 6 nipples on the abs unit) as per a workshop manual i found online. Nope, still the same
I then got a wiring diagram for the bike and started investigating the system manually, the brake levers are connected to the ZFE control module and the wiring is fine to and from them with everything working as it should, the fluid level switches on te abs pump are connected to the ABS control module, they are working ok. The wheel speed sensors obviously work as the ABS works from my earlier test ride. All the powers and Grounds are ok, I am getting CAN signal to the ZFE and ABS modules, the CAN is 60 ohms, the CAN voltages are ok and i put my oscilloscope on the CAN and the signals look ok also.
At this point im running out of ideas
So now my thoughts are -
* Its a servo/electronic issue (not ABS as this works although i know its the same system)
* The servo does not operate initially from the front brake lever but the signals are ok to the ZFE module
* The servo does operate initially from the rear brake lever and the signals are ok to the ZFE module
* fluids have been completely changed with fresh DOT 4 including all 8 bleed nipples, as per the service manual i downloaded.
* The brake lever signals go to the ZFE module then the servo operates via CAN instruction
Im wondering if the bike shop only scanned the ABS module but theres an existing code in the ZFE which may not have been scanned? If the ZFE is having a tantrum due to the voltage decaying to 0 as its been left for so long then may not have liked the bike being charged up (I did not disconnect the battery when charging, i know i should have)
I do not want to jump in and remove the ABS system, im looking for definite answer what the fault is, if its the servo/abs unit itself then i will have to remove it or get it repaired but its the diagnostics im struggling with and finding out whats wrong with it.
My Snap-On diagnostics tool will read all BMW cars, I have ordered a lead (1 weeks away) to allow my 16 pin OBD connector to plug into the motorbike but i dont know if it will be able to read it or not. It depends on if BMW gave motorbike and car ABS systems the same CAN address and if i can pull the codes from it once ive found the correct protocol.
I would really appreciate for someone to give me some more things to check / suggestions / experience etc as to if you have heard of this fault before? and where to proceed to next? I really dont want to rip it out until its confirmed as 'dead'. Bikes location is Clacton on sea, Essex.
Thank you all so much for your time in reading this (if youve got this far). I'll post a few pictures below of what ive done/ found etc
Kindest regards & stay safe!
Mark
Mark
