Originals on mine afaik, unless the previous owner went through a set in 6k miles, now on 24k and in fine fettle with no bits breaking off.
OK... Can somebody tell me whats going on here??
I recently bought some Brembo rear brake pads for my R1200GSA.
They arrived with the same profile as the old ones, however, the pad design is different (that being said, my old pads are very low and may have worn the markers off), the colour is different, and the pad material is different.
Are these new pads actually Brembo, or a knockoff?
Lack of wear-indications on the old pads is most likely due to wear.
As the pads seem to be delivered by MotorWorks, I think that if they were knockoff, MW would say so.
Since the pad material is different, I think that is the reason why the pads look different. Different colors to different materials make sense.
Genuine but not oem fitment , according to BMW parts list the LC models should be fitted with Sintered pads (part nos 34218562163)
Does anyone know what the difference is between Sintered and Carbon Ceramic?
To make a long story short.
They differ in friction to the disk. Racing type pads (Sintered) offer the best friction, as in more aggressiv braking, vs the more docile type at the other end of the scale.
To those that do not know, the word Sintered as such refers to the technical term Sintered. So, Sintered pads may be soft (short life span = high friction) or hard (Less friction = longer life span).
The trade off to better friction is a shorter life for the rotors. So, then it is up to decide for the personal needs for the rider.
The Carbon seen to indicate a fast road usage with all round premium feel and good wear , sure you can cope Warlord Hope this helps you .
Well, did 250 miles today and once they bedded in, they were great, no problems at all.
If they wear better.... total BONUS
I hope not across the border ... glad your happy , may try a set myself as on set no 4 now , 10k .
Need to ride smoother .................
