Probably obvious to most but not to me. I have stains where a previous petrol leak left brownish marks. As the grey cases are coated in some kind of film what is the best method of cleaning please? Thanks in advance.
Yes exactly, but not quite as bad.
Hello Dub 24.Hey Feisty I'd be interested in the details regarding the air brush kit you bought if possible please.
Dub 24
I'm glad to have helped. I found these pics of g650gs plastics that I did some localised repairs on. I visited the local body shop paint supplier who colour matched 20ml of the paint for me. The cost was approx 10 quid.
The colour is slightly out but a way better match than it appears in the sidecover pic and is not noticeable on the bike.
The triple clamp got silver with 2k semi gloss clear over the top.
I use it more for frames, engines and bars etc because the colours are a little more standard plus usually I am not trying to achieve a brand new look but something that will blend in with the overall patina of the bike
Sent from my SM-N975F using Tapatalk
I find it so economical with paint I haven't needed to use to bigger 30ml paint pots that came with it. I use the easy to clean 7 ml paint cup.I really need to get a bigger paint reservoir for my airbrush because it’s a tiny little thing designed for detail work only but the brush is a decent enough double action one and I’ve got a very quiet mini compressor to run it rather than use the big one in my workshop.
The difficult part will be remembering who the manufacturer was
Yes. I has a 2k semi gloss clear coat over the paint. I find most paints seem to dull off after a while. Unless it needs to be have that flat look I usually put a clear coat over the top to aid cleaning and to keep the job looking good for longer.The finish on the yoke looks just like the engine casings. Does it have lacquer added?
