2007 Challenge f/s
Not open for further replies.
big fella
Nearly Redundant
Drogheda
I thought I'd try selling this here as I'm not sure there would be much interest in the UK.
It's a 2007 bike with 13k klms on it. I bought it in 2010 for a trip that never happened. It was extensively prepared for that trip. There was a intermittent starting issue and that was sorted. The engine was serviced along with a valve check, all ok within spec. The water pump was done, swinging arm bearings and wheel bearings were replaced along with schieffelmier stainless wheel spacers. Hyperpro front and rear suspension was also fitted. The rear is adjustable. A steel subframe with Touratech racks and luggage plate were also sourced. Touratech fuel tank fitted and new petcocks were installed in march. A new odyssey battery was also installed in march. There is an SR racing exhaust and foam air filter fitted also. There is also a Scot oiler and centre stand fitted. Both fairings are included along with the headstock bracket and hid lights. All the original parts are going with it, front mudguard which is damaged but repaired, side panels, airbox cover, exhaust and aluminium subframe and a few other bits and pieces.
Asking price is €5100
Sent from my CLT-L09 using Tapatalk
