StewMcGrew
2 screwdrivers and a tommy-bar!
And enough swearing to embarrass a sailor?
Grow a pair and undo by hand. They should never be that tight when fitted or removed.
On a serious note - I had an RS in for a service, which proved to have a stuck oil filter. Best efforts with the correct tool simply rounded the hex-shape on the filter base. My solution was to drill 2 holes in the tool and insert chunky self-tappers through the holes, into the filter. It was a bit messy, but the filter finally budged!
No please. Don't put ideas into peoples heads.
I've had two BMW's in where the owners have gone down this route and the screwdriver has punched through the filter and carried on into the thin casing where the filter is recessed.
It was a joke, but I see your point...
Insert a sheet of folded in half sandpaper into the filter tool. Hit the filter tool forcing it and the sheet of sandpaper into the filter. Then undo.
I think I tried that, as you posted the advice once before.
Encourging people to drill holes into the filter which then leaves them unable to ride the bike anywhere to get it fixed isn't a good idea.
True. Your way's better.
Plus have you ever tried to remove a stuck filter base after the filter body has been torn away..
That was my fear. I guess the sandpaper trick could so the same, but probably less likely to.
https://www.ukgser.com/forums/showthread.php/534865-R1200-Tools-Clearout
£8 posted now for the one you need.
