Get the dealer to check the Outstanding "Campaigns" against the frame number They would be real Dicks if they had not done this when the bike came inI found this:
"TIP: Older 1200GSs – make sure you have the latest UCU software upgrades as there was a problem ) on 04 and 05 1200’s where the CANbus system was not shutting down aux sockets etc after ingnition switch off. TEST: see if the hazard warning switch “light” on the left handlebar goes out after 30 to 60 seconds. If not the software upgrade is required".
It seems my bike has not had this upgrade.
Why and Why??? LI Ion do NOT give the same capacity for cranking particularly in cold weather!I have been trying to sort out the issue with the bike over the last few days, I fitted a Shido lithium-ion battery which gave me more space in the battery area, I fitted a circuit isolation switch on the earth cable.
I then found the bike would barely run, clearly running very rich.
[/COLOR] I took the plugs out and cleaned them with a small blow torch. I then took off the Dynajet Power commander unit,as far as I know returning the system to standard, finding some connectors were dry and corroded, in particular the throttle position connector on the left, I cleaned and WD40'd them. The bike will not run.
Okay Did you do the Air filter?? Even just Did you have the tank lifted?? If you did you likely pulled the cable on the left throttle and the TPS sitting open and telling the ECU "Bung in more fuel I am at 45 degrees here!!" as per purple bit aboveP.S. The independent mechanic told me they had cleaned and lubed all the connectors, no they had not. The connectors I undid to remove the Dynajet kit were dry and corroded. I suspect the diode issue is the origional problem, but it looks like something else is wrong now too. I have just replaced all the discs, pads, tyres oil and filter...
Any suggestions? Apart from set fire to it.. And buy a Honda.
It has a new Varta in there now..
