This is great. LINKY
I fitted it following a series of brake light failures several years ago. Price has gone up a bit, seem to remember I paid about £35
So bit the bullet and changed from HID to LED. The ones Gabriel_GS used were currently unavailable (4000LM per bulb, 6500K), so I went for the newer, brighter version (9000LM, 6000K) which have a fan and cost £40. I needed to modify the metal bulb holder slightly so allow the notches to align, but no big deal with the Dremel. Also picked up some LED dust caps which slot straight over the top, leaving loads of space around it so the original ones are now superfluous. I also drilled a small hole on the underside to help with cooling. Replaced the stock connecters with waterproof bullet connectors and tidied everything up with cable ties. Looks good to me, but its too light right now to test them properly and the MOT is tomorrow... fingers crossed, and hopefully, they last!
I can’t remember what size of bulb the 1150 takes. Anyone able to confirm before I start delving through the books.
Ta.
I’ve just got some similar ones, what do I do with the plastic ‘screw cap’ that fits on the back of the light obviously the bigger bulbs mean the cap doesn’t fit back on -
Are they ok being exposed as such??
Mine have been exposed for eighteen months or so and have suffered no ill will so I think they'll be grand.
Hid's are an MOT failure,
for motorbikes it's if and only if they are fitted to headlamp unit's they are not approved for
Hid's are meant to be in self leveling headlight's units fitted with a wash
& or wash wipe system to prevent glare to other road users.
So if you retrospectively fit them to your bike, technically there not approved for a boggo reflector lamp unit hence the fail
But it says nothing about LED, other than they are legal as a light source
So Hid no ... LED yes
You need to consider how you wash your bike
I beg your pardon.
This bike washing you speak of, is it a regular happening at all? And if so, how come no-one has shown me how it is done?
The alternative for an 1150 is to go old school UKGSer farkle - Early 2000,s many an 1150 had these.
Just found a new unused set in my lock up - Mine were fitted by Greg Masters
