You need to ascertain where the noise, more likely turbulence, is actually coming from. Mirrors, up-draft, screen setting or your helmet itself - skirt, vents or visor. Then ear plugs - get SNR35+ as suggested already & make sure you roll & fit them correctly - hair in the ear canal leads to them dislodging easily when you turn your head, say at a junction. Some riders find it best to moisten the ear canal before fitting.
TBH we have done this one to death on here. The fact is we are all different expectations, height, limb ratios - what works for one rider may not help others. Even our riding gear matters - leathers usually smooth out the airflow better. Why not take a short ride, with the screen set low & experiment until you find the sweet spot & then look for where the turbulent air/noise is coming from.
If it's just you lid, then gaffer tape over the vents progressively, & visor edges, until you find the culprit. Up-draft can be lessened with 'winglets', maybe adjusting the angle of the mirrors will help. Finally a different screen may prove to be the answer, but they can become a money pit so take care to check everything out logically first, before opening your wallet.
Have fun. We have all been there, but our solutions will always differ.
