djheaton321mentioned putting one in one of Mark's number plate boxes which would be a similar solution but I'm concerned about the heat from the (bloody noisy) Akropovic 'silencer' and I'm not sure how I'd get all the wires to it without disrupting the integrity of the box. I should have asked when it was suggested.
The toolbox is a lot closer to where everything needs to fit so the cable run should be less of a problem and exhaust heat not an issue but how did you keep it watertight?
Cymarc does list one for the 1250GSA but it appears to fit where the pannier goes so unless I'm mistaken it won't fit when the panniers are on. Given this one exists I assumed the one for the 1200 that fits inside the pannier rail won't fit the 1250. It's definitely worth an ask though. Thanks for the suggestion.
On our HD Super Glide I was only able to resolve the placement issue by cutting a hole in the bottom of the seat and putting the Autocom in there but there's not a lot of padding in the GSA's seat so I'm a bit loathe to try that.
Kevin
Kevin
