What’s the plug on the business end of that called? (Not the spade ends). I could do with a couple to make up my own leads.
Many thanks Mike..Tight but doable without removing any bodywork.
I think I used the original bracket but had to move it slightly
If you're in my area call in for a look and a brew
Mike
Many thanks Mike..
I'm not that far away from you (Huddersfield)
So may take you up on that if I have any issues - so thanks again.
Have you any pics of your installation?
Sent from my SM-G955F using Tapatalk
Hay mate,
I just fitted a 5 Series (part no 7159421)low tone horn to both my 2015 RT and GSA! Yes plug and play and direct swop on both! Just need to bend th bracket about 2-5mm to allow the bigger unit!
Load as feck! £7 on eBay each
Cheapest mod ever! FACT
Hi there, I purchased the same 5 series horn a week or two back and haven't got round to fitting it yet. Did you have to ntake a lot of the Tupperware off to fit it? Tip's, trick' advice appreciated.
Stay safe and well,
Tony
x2 for the 5 series car horn option. Works a treat and cheap as chips. From memory I think the same (or very similar) low tone horn was fitted to an earlier gen of 1200RT?
If you've not seen it, this is worth a look: https://www.youtube.com/watch?v=MJVf70e1Lfo
The 2005 RT had 2 horns. F....loud.
