Colk
Hi all,
I recently bought a R1150 and went about servicing the brakes.
However, the rear brake caliper is putting up a bit of a fight. I removed the small clip that secures the pin in place but I cannot drive the pin out towards the rear wheel, its stuck fast.
I've taken the caliper off, supported it on a piece of wood and really hit that pin hard but it still won't move.
I've sprayed WD40 on it and left it for now, until I come back to it at the weekend.
I've also tried to clean up the exposed bits of the pin so it should slide through the holes in the caliper easier but still no joy.
Just wondering if anyone else has had the same trouble and if so how you managed to get the pin out.
I guess heat may be the next step but with the rubber boots of the caliper nearby I didn't want to try that just yet.
Any suggestions appreciated.
Regards,
Colm
Regards,
Colm
