Inusleroux
Hi All,
Its been a while,
I use to have a 2006 GS (abs) and guess what, one day doing a 3000mile trip speedo dropped out and all warning lights kicked up. Anyway investing in a Motoscan diagnostic tool i came to the conclusion the problem was at the rear... a little corroded wire.
About a year ago i upgraded to 2011 GSA non abs, Great! Drove to MOT the other day fine, week later drove to the shops and guess what speedo dead!
Here goes, i have another rear wheel speed sensor, changed it. Not that. No metal filings on the sensor all look good at the rear. Wire/ loom strip back to Tank looks ok, there is a join in one wire soldered don't know why but its good.
Checked the plug at instrument cluster, Checked instrument cluster with diagnostic tool everything moves etc. Only test i cant do is speed sensor test as tool says this figures come from abs module, that i don't have.
So much for thinking " no abs no electric problems anymore "
Does any one have any better ideas? Please any advice will be much appreciated!
Only next thing i can think of is remove tank and check rest of wiring maybe send instrument cluster away to get tested, does anyone know how to check the rear speed sensor? I can only get a ohm reading from both off them but i read on here its a volt reading?
Thanks in advance.
Its been a while,
Thanks in advance.
