Hi,
I am just getting around to fitting the Fuzeblock I had on my last GS to my new R1250GSA. I can't remember exactly but IIRC i took connected the witched live feed from a wire in the connector block under the riders seat up close to the fuel tank.
I have seen the post on the Power Splitter and thought that would offer a good solution in terms of connecting into the harness without cutting into any of the actual harness itself. However on reading various threads a few questions have arisen which are as follows.
1) Will the power lead splitter cable as used in the Power Splitter Thread fith the Din Socket on the R1250GSA. For reference the
tread describing it is at this link.
https://www.ukgser.com/forums/showt...-power-splitter-lead?highlight=power+splitter
2) I saw it mentioned that although the din socket power normally switched off after a short delay when ignition is turned off it
was suggested that it can stay live if there is some current draw on it after ignition is turned off. Is this actually the case I
had been going on the basis that this always powers down albeit maybe after a short delay which is important as I want to
be sure that all accessories wired to the fuzebloack get shut down when I turn off the ignition.
3) Anyone got any other suggestions as to where to take the power for the switched live from that might be easier and better
than what I am considering.
Be grateful for any comments and information.
Regards
Brian
Regards
Brian
