I have a 2003 twin spark 1150RT with nothing wrong.
The ABS works fine, the Servo brakes work fine. Only have 63k on the clock. Worth what? £2000 - £2300?
Recently changed out the fuel pump and filter, went over and tidied up all the electrics & sorted out any iffy or frayed bits.
Stripped out the alarm system as that was giving out an odd squeak every once in a while.
Removed an aftermarket radio and OEM speakers as I could not hear much over 65mph with it on full blast - which made me cringe at slow speeds through traffic and built up areas.
Suspension is fine, no issues. Recently renewed the rear wheel big hub bearing.
Full 3x hard luggage boxes with a scrape or two but no leaks or hard damage.
I have since this photo changed the top box to a Hepco and Becker 52 litre which is colour matched, removed the orange stripes, fitted a voltmeter, hard wired a garmin satnav, fitted 2x standard ciggy lighter outlets into the glove box, (great big deep bugger ennitt!) fitted LED front lights and fitted a larger touring screen.
But I keep on being distracted by the 1200RT as it is 4 stone lighter...........
Is that enough reason to change I wonder?
