Anyone know of something which fits around the ignition to stop keys and fobs marking the yoke?
Could do, just a nuisance then finding top box and disc lock keys. There’s also the central locking remote and the tracker fob, which seem to leave black marks below the ignition.
Key pouch?
There was a chap selling BMW Motorrad ones on here some time ago.
Thanks for this. There is an item for the 2005-2014 R1200RT but can’t see anything for the R1250RT. Do you know if the yoke/ignition key area changed between these models? Which model have you fitted the carbon to?Search for 'JOllify carbon' on eBay, £14 ish delivered for a self-adhesive, carbon fibre protector. Very good quality and a perfect fit.
Pete
Key pouch?
Put that lot on one key-fob (ideally a loop style) in your inside pocket, & just the ignition key on a second loop. The Tracker fob shouldn't be on your key ring. The tracker will activate if someone pushes your bike away, & the fob becomes distanced. If someone steals your keys, don't let them have the fob as well.
Noted, thanks.Whatever system you adopt, take note of this warning about the tracker fob
https://www.motorcycleparts-hornig.com/BMW-R-1250-RT/Carbon-Fiber-GFK/Dash-pad.html
I've got one of these on my R1200RT and also got one for the work RTP too.
