Hello and greetings from Australia.
I am having issues...
Just got back from a 2000km dirt ride, while away i noticed that periodically the idle would hang at 2000rpm instead of coming all the way back, there was no pattern to it.Sometimes it would do it sometimes not
When i got home, I cleaned everything i could, there was some slight oily sludge (Probably due to over oiling air filter) in throttle body intakes and idle motor ports.
My problem now, is, when it is returning to idle, it just seems to hang a while between 1750 and the 1100rpm. IE when i let the throttle off from higher in the rev range it comes straight back down to about 1750 rpm then sort of holds there for a split second then drops very slowly.
Any ideas?
Here's something else i just noticed,
If i turn the bike on with key and start it, it idles ok to start with.
if i turn bike off with kill switch and then back on and start bike it idles at 1750-2000.
I have reset throttle bodies vacuum gauge spot on at 3500rpm
recalibrated Idle Acutators
sprayed around throttle bodies looking for leaks.
disconnected/reconnected battery and twisted throttle multiple times
reset adaptions
I will adjust valves tomorrow and spray kill switch with contact cleaner... is there something I'm missing?
(its a 2007 r1200adv
powercommander fuel controller fitted
remus
no cat
been dyno tuned
unifilter)
Any ideas?
reset adaptions
remus
no cat
been dyno tuned
unifilter)
