Wheels
Billy Buell
Barlick
I know it,s been asked before but i can't find a definitive answer.
2014 r9t classic , are there any bmw alloy wheels that are a direct fit with the spokes going the right way ?
If you go to page 4 and scroll half way down [New Wheels] I did a post on R1200R wheels i fitted to my 2014 Nine T.
Sorry can't seem to add the link. Hope that helps.
Thanks for the pointer. I've talked to motor works today and they said they would be easier to source if i give them part numbers. Any chance of having a look as it's those paticular ones i want , it would be much appreciated.
FRONT K27 R1200R 2009-2014 3.50X17 36.31.8.529.107
REAR K27 R1200R 2009-2014 5.50X17 36.31.8.534.447
These were originally black but mine were powder coated silver when i bought them.
Saying that, i think the black would have looked nice anyway.
Must say Motorworks were not very helpfull when i was looking for mine.
Good luck!!!!! Rob.
Good luck!!!!! Rob.
Thanks Rob
I've got a front wheel sorted , i presume i need the same seals as the original but everything else fits.
If it's off a R1200R the right hand side is ok but the left hand side inner is too big.
Left hand side is 35x52x7 you need 32x52x7 same as the R/H/S if that makes sense.
Check the ABS ring mountings are the same as yours. Later ones were smaller.
Did you use that web site that i p.m you w/e ?
Yes i looked at the web site thanks. Mine is the early one with the bigger abs ring.The front is a new wheel from bmw no 36.31.8.529.107 for r1200r with one 30.52.7 and one 35.52.7 seal. So i think i need two 32.52.7 seals.
Well got a pair of wheels , a new front and a second hand rear which i've had powder coated. Very happy. I'll fit them over christmas when i've a bit of time.
VERY Nice!!!! They will look really good when they fitted and best of all. No Tubes. Win Win.:beerjug:
Yes i'll put a photo up when i get them on. Thanks for your help.
Don't forget you need the shorter bolts for the rear wheel.
The R9T are M10X1.25X53 You need M10X1.25X40 Part No. 3631 767 3903
Or just get your hacksaw out :D
I got some with the wheel. They are 40mm total end to end . Are they the right length ?
