Scrambler 1200 - munt my Garmin
xantamisch
United Kingdom
Hi
I've got a BMW branded Garmin (Nav 5)
Any ideas what I'd need to attach this to my scrambler 1200? What parts etc?
thanks
You will need either a Garmin 660 mount or a BMW four button holder. You might be better off selling it and getting a normal Garmin for your bike.
I’ve used a ram bolt replacing a handlebar clamp bolt - then a 1inch Ram mount to the rear of the GPS powered mount.
right - got the 660 mount and ram mount now, both off ebay. Currently connected into the battery
does scrambler have a fused accessory connector somewhere? dealer said not
thanks
Or use usb cable into Nat nav itself I suppose, bypassing the powered garmin mount
No. The Garmin will think it’s connected to a PC and go into a mode that means you can’t navigate.
I tried to connect my NavV to a DIN socket on a triumph T100 I rented in San Fransisco and that’s what happened. The battery lasted long enough to get me about 75% of the way on my route and then died.
ermm can you explain that idea to me? I think you are suggesting disconnecting the usb and wiring into the feed to it - but as you say, means Id lose the usb
did you put a fuse in?
are you twiz from old Ridersite days (Jorge at Renegade. Hammy, Tron etc.)?
I believe it should have a 1 amp fuse? Any idea?
The second hand mount I bought doesn’t have a fuse so I will have to wire one in
