Roymundo
I am servicing and an annual clean of my 2015 R1200RT LC with 30k total miles recorded. Whilst cleaning I noticed a black cruddy mess at the engine rear under and around the clutch slave cylinder area and onto the exhaust pipe. Not noticed that before but cleaned it down with paraffin, dried off and as yet no sign of anything weeping/leaking.
Later I checked the clutch master cylinder reservoir and noticed the fluid level is about 9mm below the vertical marker bar. The clutch lever feels fine, not spongy and gear changes are normal.
Access to the slave cylinder looks a pig and I am wanting to do any work on it myself to cure whatever needs doing.
Any suggestions of how to proceed with this possible leak/problem?
