I have got my 1974 r90s up on the ramp to do a bit of tidying and recommission work and yesterday I took the front cover off the engine to change the points . I just happened to touch the tachometer cable and it separated from its housing . So I thought I would be able to remove the housing with a pair of pliers and then remove the helical gear and the metal sleeve and oil seal .So I remove the timing cover yesterday evening to try and sort the situation. Silly me !!!
I soaked it in WD-40 overnight and with some heat I managed to remove the aluminium cable cover this morning However try as I might I could not remove the sleeve to get to the inner oil seal . In the end I thought it was better to try and save camshaft drive gear itself and the sleeve and to forfeit the cover. Very sad time !!
I managed to cut a sleeve out relatively easily using my Dremel and little grinding disc but the oil seal proved very difficult i was clearly bonded with corrosion. In its previous life there must have been problems in this area as there is an 8-mm chip on the end of one of the spiral teeth and the spacing washer is missing.
So I'm now in the hunt for a new timing cover and was wondering if any members might consider selling one to help me out. And will be 8 mm chip at the end of one of the spoil teeth be a problem or not what. Also how thick is that missing washer? Thanks guys
