No need, timing check is built in.
Ignition key off
Unplug the headlight (optional)
Remove the flywheel viewing plug in the bell housing
Remove the alternator belt cover
On the 1150: Rotate the crank by hand to a little before the 'S' mark (5° BTDC) on the flywheel
Turn the ignition key on - the fuel pump will cycle normally for 1 sec
Rotate the crank very s-l-o-w-l-y CW by hand until the fuel pump cycles again
The crank is now at the hall sensor trip point - in this case that is also the static timing point
Look at the flywheel marking to see where the static timing is set
Adjust if necessary
On the 1100: Rotate the crank by hand to well beyond the 'OT' mark (TDC) on the flywheel
Rotate the crank very s-l-o-w-l-y CCW by hand until the fuel pump cycles again
Adjust if necessary
