I’ve got a friend with a Gs911 so I’ll try and use that at some point, 8 was out on the bike last night and the right drip has failed again.
Today I peeled back the grip to re solder the joints and noticed the first wire is broken that wraps round the handlebar, after work tomorrow I’m going to try and re solder this and see if it fixes the problem.
Does anyone know what size wire would be suitable?
If it’s a thin uninsulated wire that wraps around the grip, then that is the heating element and is a special resistance wire which heats up when a current passes through it. If the break is small, then bridging the gap might not be a problem.
