Look at utube for a Jim Von Baden video on how to take off the bodywork, he shows how to undo some hidden body fasteners on a 1200 GSA. The same fasteners are found on the 1250.
Decide where you are going to put down each part before you take it off not when you’re wandering round the garage with it in your hand.
Take copious photographs as you strip each part off so you can refer to them when you come to reassemble. Especially note cable routing and how each cable connector comes apart - some are quite perplexing and different to the one you’ve just done.
Where possible screw fasteners back into their locations as you go so they don’t get mixed up (different height shoulders etc).
Anticipate where the final drive unit and the front telelever will move to when unbolted from the suspension - pack and jack before unbolting so that movement is minimalised. Tape a pad of cardboard onto the top of the front of the engine where the telelever wishbone will contact when lowered on release from the suspension unit.
Heat up (with a hair dryer), the lower rear suspension bolt before attempting to loosen it. Remember (write down) how you fed the front suspension unit out from its location ie bottom back, top out first or top back, bottom out first. It will only go back the same way, no doubt reassembly will be sometime later when you’ve forgotten how it came out.
Not comprehensive but a few tips from experience.
Alan R
Is your bike D-ESA?
Is your new shock a new BMW shock? If so check what the preload and damping is set at eg ROAD mode, ROAD damping, MAX preload.
Before starting work set the preload and damping on your bike match. If you don't do this it will mess up the calibration.
Thats the swap I made.I’m replacing the standard shocks with Touratech/Tractive shocks but interesting point you’ve made.
To get access to the rear shock, hinge the rear end out of the way! Remove the bottom frame bolts, loosen the top bolts, disconnect the ecu and other local wiring connectors and secure with a ratchet strap. Here are a couple of photographs of my 1200 GSA but the principle is the same for the 1250gs
Good luck
Alan R
Is your bike D-ESA?
Are you sure as i did that and it screwed eveything up , its Road MIN setting not MAX . Internet instructions.
https://shop.touratech.com/media/manuals/09-045-5885-0.pdf
Sorry to point out some thing that may not have been clear , that’s why I posted the link due to the issue I had , and felt your eg could be misleading and a pain to rectify. If you get it wrong it’s a right mareI did say e.g not they are, and reccomended to speak to TT for instuctions.
See post 7.
Wow, many thanks for this Denz0, that’s great,
After talking it through with Nick at Touratech, they suggested one up from standard due to my weight etc. They’ve gone up one from standard on the springs. Can’t remember what that is off the top of my head.
