So I'm a weirdO because I prefer the shaft drive over a chain
Majority my trips are 10K duration each time. . . . . Chain...... Nahhhhhh
Ah well, I'm a gay pirate because I prefer a belt!
I have owned a couple of Multistrada's and they were great fun, well balanced and L twin grunt but , on tour, especially in the Alps drank fuel at a rate that often reduced tank range to 150 miles or so. So , for example, entering the Grimsel Pass from the Furka with 150 miles range it would quickly reduce to nowt as the revs increased. I once had to free wheel down the Grimsel overtaking cars to the unmaned fuel station at the bottom. One car came in and asked if my Multi was an electric bike.
Some testers have said the mpg is 35......so this V4 has the same drink problem.
Can you remember the usage as a loop from Hotel Hof to Grimsell and the Furka and bak to the Hof is about 80 miles , hope it was not that bad ....so if you ran out ..Christ the bikes a fuel lush or did you do the figure of 8
MOTORRAD & PS had 2 interesting comparos V4 Multistrada vs S 1000XR and V4 Multistrada vs R1250GS...To sum it up the new MS lost both comparisons for different reasons...Less sporty,20 kilos heavier and 15 hp down compared to the S1000XR...0-200 km/h 10,3 vs 8,5 sec , 254 vs 232 Kg , 165 vs 179 hp...And the MS uses a liter more petrol on 100 kilometres...The XR is the better as in more sporty streetbike !
Against the GS the MS has 30 more hp but also 14 nm less Torque.That means the MS is good for 250km/h topspeed while the GS only does 220 km/h but the GS is a little faster on-roll on 60-180 km/h in top gear.The GS stops shorter and handles better thanks to Telelever and the position of the crankshaft that builds up no gyro.Also the GS uses 40% less petrol than the MS...Ridden hard or easy the MS used 2 litres per 100 km more...I think adding the chain to the whole picture the MS won't change the rules of the game which is either 1250 GS or S1000XR depending on what you prefer.Good all around bike or harder edged 4 cylinder sportbike made rideable for the road.I mean a sportbike that does not make your back,wrists and neck ache after 60 miles,a bike that can be enjoyed 2 up,your stuff dry and secure in factory hard bags and with a practical device called centerstand so no need for a pitstand littering up the garage
The next GS will be 10 kilos lighter and will have 155 hp/nm torque and will cover All bases
While KTM and Ducati have to convert to shaft-drive and Telelever if they want to compete and have a chance to de-throne the King of the Alps the mighty 1250 GS
How long did it take you to find a review where the GS actually comes out ahead of the Multi V4S ??
And the only one you could find was a German mag that always sucks up to BMW.
Are you sponsored by BMW to constantly spout such utter bollox or have you sustained a head injury in the past ?
BTW, some people actually think the GS sounds like a wet fart,which is probably about right.
BMW have been tweaking and fettling the motor for 40 years and it still makes the least power of nearly all its rivals.
Even the new Harley Pan American makes something like 20bhp more and that’s the first incarnation.
The development of the Boxer engine is coming to an end.You can only polish a turd for so long
MCN came to the same conclusion
Sven you shut up Arsey quick...
MCN must be another german publication or simply fake news...
Looks like if Ducati wants to sell the new MS the should give Foggy one for free to flog it in the next episode of king of the jungle...
