The venting is one of the things I am worried about, The Rallye with all the vents open is very good. I wondered how good the venting on the Klime BP is ?
Which Rallye version did you come from ?
The only answer is try it, I find it a PIA, and dislike the design.
for me the issues, the inside pockets are non existent, a couple of mesh bags that catch on almost anything you put in, the outside pockets on the upper chest are ok but small, awkward and NOT 100% waterproof, stuff gets damp not soaking but damp, I have an issue with the sizing in that when they size up the jacket they dont seem to size up things like zips so for some the front pockets are fine for me the openings are small for my xxxl hands especially with gloves on, there is new level 2 body armour and the elbow ones are a nightmare they never stay in place you are supposed to use the straps around the arm to secure things in place which is fine except when its hot and the fact you have to adjust them every you take the jacket on or off. There is a water pouch pocket on the inside of the jacket on the back that sits behind the back protector, what a waste of time as when you fill the bladder and put it in place it reduces the amount of space in and around the jacket in conditions when its hot or why would you be using the bladder in the first place and you want lots of room and airflow??
Oh and I have no idea what the pocket on the arm is for, I believe its for a gps device, but it would only fit a "spot" and nothing else and its just in the wrong position to actually get anything in or out of without first taking off the jacket, not a fan of the collar holding open design as there are two thin elastic loops that hook onto the plastic bits on the jacket, its a design used on the Revit jacket which I used to have and lasted about 12 months personally I preferred the popper on the last version, nothing much to break and nothing to catch,
It is very waterproof, I find it pretty comfy to wear, it is lighter than previous versions but if I had a choice I would have had the previous version or the version one. I like the fact that it is a shell jacket as I like to be able to wear what layers I like underneath, it appears to be hard wearing although the fabric is a lot lighter and does not appear as abrasion resistant as the fabric used in previous versions of their jackets both badlands and adv,
I will be upfront, I was sent one as a warranty replacement for my Adv jacket, its not a patch on that one so I may be unfairly comparing it, however I personally would not buy one, but it may fit you better and the things that bug the fuck out of me may not you.
In short it is very very well made, but I think it is a piss poor design to live with long term.
Hope that is of help
The pocket on the arm - medical card.
From a Rallye 3 too. I kept both for a while, but the Klim was always the first choice.
The Klim is ‘stiffer’ for sure so initially not as comfortable out of the box so to speak, but that actually helped me retain good posture on the bike as odd as that sounds. It’s not as cool as the Rallye with liner out, but overall, expecting all weathers it’s the best I’ve had.
Hot weather only, the Rallye probably does the job just as well.
Edit after reading above...
Fit is a bit different, which is why I bought from a physical store, but it suited me.
As a direct comparison with the Rallye, it’s a better jacket in my opinion, not saying it’s the best available.
no not the forearm the pocket on the right upper arm, it is supposed to be for emergency device but only fits the spot, wont take the Inreach or Garmin
Thanks for your valued experience in this jacket.
Thinking about my Rallye 3 jacket, I only use one inside pocket for my phone, everything else I carry is in external pockets, which are not waterproof.
Lots of info there for me to chew on. Cheers.
Is it £500 better?
The small sleeve pocket would fit the SANEF toll tag?
I think i may just buy this jacket......
I use the lower arm pocket for my debit card to use at tolls and refuelling. Ideal for a toll tag, but not sure how big that is - it’s not a big pocket at all - debit card sized and not ‘fat’.
Tough call on value, as we’re all different, but I think it’s worth more, but £500 more? I bought it, so guess my answer would be yes.
The kidney belt was a revelation for me. The chest protection a bit fiddly, agree on the internal pockets, but despite the previous comments, I found a perfect armour fit. I popped on a few pounds and there’s not much room for expansion, so please ensure you get the right size too.
The size is another issue, S,M, L, XL, 2XL etc etc My Rallye is a 58, so is that an XL ? I really need to try them on.
#They size small, so please do try on and with the expected number of layers you ride with. Personally I have a long sleeve base layer and tee shirt only, which is fine for regular UK weather, but add a fleece in winter, remove the base layer in hotter climates.
I came from a Rallye 2 to a Klim Badlands. BMW were changing the Rallye and none were available in my size.
The jackets are chalk and cheese. The Rallye is comfortable soft easily vented and all day comfy. My Badlands is stiff , bit like wearing a suit of armour, complex eg tucking the chest armour pockets out of the way and lastly doesnt vent as well.
Which jacket would I wear in a downpour, the Klim every time, with its three layer goretex pro textile.As a lifetime jacket, this will outlive a cockroach.
As an everyday jacket for me its too full on. Which is a pity as it cost a fair bit.
Steve
Steve
