BigKev67
Today I had a dealer test ride on a GSA 1250 Adventure TE Rallye.
I found the ROAD throttle response a bit slow, DYNAMIC was better. The switch between ROAD and DYNAMIC seemed to also switch between the damping settings, also called ROAD and DYNAMIC
So as I dont have a bike to play with I have a question. If you want to have a DYNAMIC throttle response but prefer the softer ROAD damping setting can you do that or are you stuck with ROAD/ROAD and DYNAMIC/DYNAMIC.
I understand in the PRO mode you can customise a Throttle setting, but I am not sure if that customisation includes damping. Also its odd that you are stuck with only two damping settings, it would be nice to be able to dial in your damping.
