R80 G/S master cylinder
SteveHop
Northamptonshire,England
I noticed that with the bike on the center stand -
- if the handlebars are turned to the left i get a "drip" of brake fluid on the underside of the master cylinder.
- if i turn the bars to the right no leak ?
Ive check it a couple of times and can't make it out ?
Not sure if its worth getting a master cylinder rebuild kit ? Or can i just replace the seals ?
Thought i would just change the resovoir O ring first although im not sure if that would solve .
Any ideas ?
Thx
Without stating the obvious, there should never be any leak. I’d get a new piston kit with seals installed ( I’m not sure if you can buy the seals on their own anymore), new reservoir seal and if need be a new hose and washer.
I like the Venhill engineering ‘ build a hose’ option from their website. Using the black hose and black fittings I think it looks good. Not too snazzy and not too ‘custom’.
I couldn’t find just seals so bought a full piston kit from Motorworks. Dead easy to change, just make sure you get the correct diameter.
