Blimey, I’m worried now!
Sort it sooner than later, rather than have the £5k bill for the rebuild - ask Mrs Berin
having built more 2 valve flat twin engines than anybody in this country there is a machining fault with the oil feed on the late model crankcase normally in the 1990s which leeds to very slow self destruction, hope you dont have one.
That’s interesting, what are the self destruction symptoms? Mrs Berins one did end up a mess, now sorted by Mikey, but it was a conundrum how it happened as it had good history and careful owners
There are no symptoms, it just wll not live to be an old bike with a lot of miles, and unless you make a mod it will do the same again, just how many miles it will manage is dependant on the severity of the fault. ignorance is bliss.
BMW know nothing about it. and yes it effects oil feed. i only found it in 2009 when i had an engine brought to me that had done a bottom end for the 3rd time and the owner had lost all faith in the guy that had built it. i now fix the problem on every engine i build. you just cant say if its good very rare in the 1990s, they are normally between 60% oil flow down to 30% oil flow. to fix it or find it requires a total strip down. normal BMW repair shops would not even look for it , why would they. they just fit some new parts and all is fine again, but you are on a ticking time bomb.
