firium
Hi guys,
I'm having the strangest issue with my GS and was hoping that someone would be able to help with the diagnosis? I've searched here and elsewhere and not yet found any other reports of this.
At low speed, when tying to take the steering past ~1 O clock to the right, ocasionally the handlebars will resist being turned. If this happens, the bars can be turned left. Further pressure to the right will result in a click feeling (no sound as far as I've noticed) and the bars will turn freely again. This only happens now and again, on my 45 minute commute maybe 2 or 3 times. I cannot seem to reproduce it when stationary. The issue seems to clear either when I push through the resistence, or when I stop.
I've checked all the lines from the bars and everything seems to be where it should be. The steering lock was my next guess, but I've not been able to confirm it as the cause - the lock mechanism seems to be behaving normally. Could this be down to a bearing issue? It certainly doesn't present like any bearing failure I've seen before, the steering feels smooth and notch free otherwise.
I was wondering if anyone has come across this before and may be able to point me in the right direction regarding a fix?
Any help greatly appreciated. Thanks
