On the underside of the fuel tank there is a small tube which looks like a breather/overflow, should this have a hose attached to it or is it nothing to do with that?
It’s an overflow from the filler area. G/S tanks with the filler cap standing proud don’t have it. It should have a tube running to below the engine but all I’ve worked on had the tube missing so I’m not sure of the route if you’re after factory correct.
